1954 Dodge C1 Pickup Hot Rod Build Thread
+8
RidnLow
Highwayman
dodgeboy
ThompsonsGarage
12 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: 1954 Dodge C1 Pickup Hot Rod Build Thread
this are really shaping up here. great job steve
i really like what you are doing thaks for sharing
Highwayman- Posts : 29
Wow....Holy crap!! You are doing an outstanding job!! You are doing everything to that truck that I want to do to my 56, only yours looks professional and great!!
Keep up the great work and keep those pics coming !!
AkBillyBow
AkBillyBow
AkBillyBow- Posts : 12
I have some questions if you don't mind. What engine are you installing? Are you using motor mounts or motor plates? How far back did you make the firewall, where the engine sticks into it? What thickness sheet metal did you use for the firewall and for the cab floor?
I am building a 56 Dodge and am installing a 440 with motor plates, and of course I am running into all kinds of battles! I am really going to have to cut into the firewall deep to get enough clearance for the big block!
Thanks for your help. Your build looks great!!
AkBillyBow
AkBillyBow
...why use a plate? seems that individual mounts would be easier to install unless this is a drag race thing.
I am using plates for clearance issues only. It is very hard to squeeze a big block in the coke bottle shaped frame, with an IFS suspension up front. No room for engine mounts, headers, or steering linkage. I am heading out to work on my truck now, and will determine for certain if I am going with the plates....but I am leaning that way.
Only thing with the plates is I don't want to mount them rigid to the frame. Trying to work out some mounting system where I can use bushings to eliminate some of the vibration. Trying to get the best of both worlds here....but it is not easy!
Thanks....AkBillyBow
All dependent on how/where the ends of the plate meet the frame there are plenty of 'biscuits' that will work for the cushion. Look at the transfer case mounts in a 70's W-150-200.
Thanks 73rr !!
» 60 Dodge pickup Build
» 1957 Dodge "Penny" build thread
» 69 adventurer build thread
» 60 Dodge Pickup
» 81-93 Dodge Picture thread
» 60 Dodge Pickup
Page 4 of 4
