1954 Dodge C1 Pickup Hot Rod Build Thread
Page 2 of 4 Previous  1, 2, 3, 4  Next
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Started mocking up rear axle and bedsides to design C-Notch and rear axle width
Post by ThompsonsGarage on Thu Nov 06, 2014 5:17 pm
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0519
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0520
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0521
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0522
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0523
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0524
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Thomps10
ThompsonsGarage
ThompsonsGarage
View user profile http://www.thompsonsgarage.com/
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Current mock up picture
Post by ThompsonsGarage on Thu Nov 06, 2014 5:19 pm
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0525
ThompsonsGarage
ThompsonsGarage
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Re: 1954 Dodge C1 Pickup Hot Rod Build Thread
Post by rich on Thu Nov 06, 2014 6:46 pm
moving along nicely will your rear baggs be on a lever setup or cantilever?
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 <a href=1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 59dodge_zps72ab4768" />
Post by ThompsonsGarage on Fri Nov 07, 2014 10:15 am
I am going to be using the same style adjustable coil over as the front suspension and a triangulated four link set up. I wont be using any air ride on this truck just going to get a super low stance with the coil overs.
ThompsonsGarage
ThompsonsGarage
Post by rich on Fri Nov 07, 2014 11:38 am
nice...
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Working on firewall patterns
Post by ThompsonsGarage on Fri Nov 07, 2014 5:48 pm
Starting to make patterns for the firewall - got to decide if I like the layout before I bead roll some designs in it.
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 <a href=1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0526
" />1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0527
ThompsonsGarage
ThompsonsGarage
Post by rich on Sat Nov 08, 2014 8:45 am
that looks like it will work out
Post by Paul on Sat Nov 08, 2014 9:12 am
yeah i like it
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Sch710
Post by dodgeboy on Sat Nov 08, 2014 11:22 am
will you make it in one piece ?
dodgeboy
dodgeboy
Post by R.A.D on Sun Nov 09, 2014 10:31 am
like your progress
Post by ThompsonsGarage on Mon Nov 10, 2014 8:01 pm
Paul wrote:yeah i like it
Thanks - The panel looks great
ThompsonsGarage
ThompsonsGarage
Post by ThompsonsGarage on Mon Nov 10, 2014 8:02 pm
dodgeboy wrote:will you make it in one piece ?
It is designed with small reliefs so you can bend it over and have a perfect joint to weld so I guess in a way it is one piece but you still have to weld all the sides.
ThompsonsGarage
ThompsonsGarage
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Started on firewall and toe boards
Post by ThompsonsGarage on Mon Nov 10, 2014 8:05 pm
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0510
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0511
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0512
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0513
ThompsonsGarage
ThompsonsGarage
Post by ThompsonsGarage on Mon Nov 10, 2014 9:18 pm
Sorry I thought you were asking about the Mustang II crossmember.
The firewall is made with a total of 5 pieces. I had to do it this way because my bead roller only has an 18" throat on it. I wanted to make as one piece but then I would have had to leave everything smooth and not roll any designs or strength into the pieces.
ThompsonsGarage
ThompsonsGarage
Post by R.A.D on Tue Nov 11, 2014 10:43 am
looks great
Post by rich on Tue Nov 11, 2014 2:19 pm
yes it does look good very clean
Post by Paul on Thu Nov 13, 2014 8:14 am
thanks. your firewall is the best
Post by RidnLow on Thu Nov 13, 2014 6:53 pm
nice progress Smile
RidnLow
Post by Highwayman on Fri Nov 14, 2014 8:51 am
that's cool the way you made the patterns for the firewall
Highwayman
Highwayman
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Metal Finished Firewall and Toe Boards
Post by ThompsonsGarage on Mon Nov 17, 2014 3:52 pm
Just completed metal finishing firewall and toe boards. I have a few areas I need to touch up before I call it done.
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0514
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0515
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0516
ThompsonsGarage
ThompsonsGarage
Post by dodgeboy on Mon Nov 17, 2014 5:17 pm
that is awsome. metal finishing takes some time
dodgeboy
dodgeboy
Post by rich on Thu Nov 20, 2014 9:52 am
coming along nicely looks fantastic
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Finished Repairing Inner Cowl to Toe Boards
Post by ThompsonsGarage on Sat Nov 22, 2014 3:48 pm
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0517[/img]
ThompsonsGarage
ThompsonsGarage
1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Empty Started Fabrication of New Inner and Outer Rockers
Post by ThompsonsGarage on Sat Nov 22, 2014 3:52 pm
[img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0518
[/img]1954 Dodge C1 Pickup Hot Rod Build Thread - Page 2 Img_0519
ThompsonsGarage
ThompsonsGarage
Post by rich on Sat Nov 22, 2014 6:28 pm
are those scratch built rockers? toe boards look fantastic
