46 dodge 4X4 custom
+7
Highwayman
dodgeboy
T Hilde
11 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: 46 dodge 4X4 custom
nice videos.. glad to see this moving on its own power
R.A.D- Posts : 114
hey T awsome videos just in time for the snow LOL
RidnLow- Posts : 21
Things have slowed down on this project. Planning the box project now. It is still inside for work but at the back of the shop. Gotta finish the 49 Chevy PU on the Dakota chassis. Need a driver by spring and it is farther along than the dodge. But the dodge got me through builders burnout on the Chevy.
T Hilde- Posts : 44
T Hilde wrote:Things have slowed down on this project. Planning the box project now. It is still inside for work but at the back of the shop. Gotta finish the 49 Chevy PU on the Dakota chassis. Need a driver by spring and it is farther along than the dodge. But the dodge got me through builders burnout on the Chevy.
wow chevy on a dakota chassis. the Gods are restless LOL
R.A.D- Posts : 114
Picked up a wood wheel for the truck.
T Hilde- Posts : 44
Been about a year gone by on your nice build. Is it on the road yet?? Looked like you were coming right along with it. CG
country gent- Posts : 11
Had another project that was started first that is close to finished. It still runs and drives around the yard. Working through what box I want to use. Hopefully find an old wrecker bed from the 30's or 40's. Heading to a yard this weekend to look. Thanks for checking in!
T Hilde- Posts : 44
Got a little update. I recently picked up an over-sized glove box from I-R-POPS Designs (a dodge guy from another board). This week it got installed. Instead of using the factory springs on the door and cutting into the box, JB Weld was used to attach 2 strong magnets at the top of the opening to hold the door shut.
T Hilde- Posts : 44
Did some more work on the Dodge yesterday. Noticed the hood line looked off on the cowl and made some 1/2" spacers for under the cab. Straightened the rocker panel under the passenger door. Cut the slots in the running board brackets and test the boards to the truck. Now to decide on welding or bolting them on.
Found out that a 52 dodge box will be a better fit on here. Now to find one at a reasonable price.
T Hilde- Posts : 44
i'd just bolt them on for maintanance
dodgeboy- Posts : 39
Was going to finish the running boards today. Noticed the hood didn't fit right up front after shimming the cab. Also saw the radiator touching the steering gear Took out the step brackets and installed 5/16" cage nuts. This way I can move them forward a half inch. Drained and pulled the radiator, then went to dad's to help him on his tractor. Got back 3 hours later to find a slow drip that I had a quart can down to catch, was about 2 quarts :mad: Got the inside of the nose notched and the radiator support by the steering gear (dad's fighting tractor followed me home, bad JuJu). Finally have everything back together good clearance and the hood fits better. I was a filthy, dirty, sweaty mess. :eek: Maybe tomorrow the running boards will be bolted to the frame.
T Hilde- Posts : 44
Finally got the running boards finished. Bolted the brackets to the frame. Lots of cussing.
Installed the drop down battery box. Needed to file the edges when it cut my thumb.
Made a bracket to mount a parking brake lever to the transmission.
Vacation is over, time to go back to work.
T Hilde- Posts : 44
Nothing like playing with your wood to make you forget a bad day at work. I picked up some 3/4" plywood so I would have extra support under the metal floor I made. Even though I missed a little on the center stick, I may forget about the metal piece. Some fiddly fitting and I can get the holes drilled for the 1/4" hold down screws.
T Hilde- Posts : 44
Got the fit and finish on the wood floor board done. Got the wife into the shop to turn the wheel on the bead roller to get the toe board done.
Found some scrap steel at the recycling yard that fits the peak on the nose for a bumper. Made a little jig to help make the cuts.
Took some scrap channel iron to make the mounting brackets.
T Hilde- Posts : 44
this thing is really coming together. good job
R.A.D- Posts : 114
Brings back a lot of memories from doing my 52. Nice truck.
70chall440- Posts : 273
» 1953 Dodge custom build.
» 76 Dodge 700
» Hi, Dodge fan
» WE NEED PICTURES
» How about some pics of 61-71 dodge trucks
» 76 Dodge 700
» Hi, Dodge fan
» WE NEED PICTURES
Page 3 of 3
